adding keyless entry to a '95 civic?
Old Feb 18, 2007 | 09:29 PM
stabmaster's Avatar
Default adding keyless entry to a '95 civic?
Is there a factory module/part to add keyless entry to an existing civic with electronic doors? if not then is there a preferred aftermarket unit? I saw one on ebay which stated that it was for "all hondaswith factory keyless entry" but i doubt that to be true for some reason.
Oh also: i got my honda broken into - someone drilled into the lock cylinder. i was wondering if i could just swap the cylinder from the passenger side to the driver side and just put something like a carriage bolt on the passenger side. i dont' see a need for another cylinder if this is possible. I never use the passenger side key cylinder
Old Feb 18, 2007 | 09:33 PM
jake11375's Avatar
Default RE: adding keyless entry to a '95 civic?
Just get an alarm, especially since your car just gotbroken into.That will take care of your keyless entry as well. $150 should get you a decent alarm system.
Old Feb 18, 2007 | 09:56 PM
b8teen's Avatar
what he said....but dont go to audio express
Old Feb 18, 2007 | 10:01 PM
jake11375's Avatar
For the lock cylinder that got drilled out, if it can just be replaced tofix it,try few salvage yards before you resort to the dealer. Make the dealer your LAST stop. Good luck getting it fixed...
franzcatch
Nov 29, 2010 06:40 AM
Civux
Sep 25, 2007 08:26 AM
93Miata
32
Nov 10, 2005 05:03 AM
phearly
Oct 26, 2005 02:40 PM
Korks101
Oct 18, 2004 03:44 PM
