timing problem
timing problem
ok so my question is @ what degrees should i adjust the **** on the timing gun for a jdm d15b? also if i'm not able to move the red line to where i have to be what way would be the easiest to adjust??any help??
RE: timing problem
just adjust the **** until it lines up with the marks on the plastic cover and the crank pulley. Look at the timing light and thats what your timing is set at. now loosen the distributor and move it back towards the front of the car to retard and towards the firewall for advance.
RE: timing problem
yeah cause i read that diy on timing but it would tell me to put it at 16btdc and i would but the red line would be about on the left side on the crank i could only see the 2 lines that are on the far right of the red one. but that helps thanks
timtimmah
02-15-2007 03:55 PM
