adjusting valves on 1998 civic ex
Old Feb 19, 2007 | 09:22 PM
greencivic's Avatar
Default adjusting valves on 1998 civic ex
i've got a 1998 honda civic with 98thousand miles just did a timing belt and water pump catalytic converter ,first bank o2 sensor ,ran sea foam though trotle and vacum lines to injectors run's real good ,but i've got a problem with emissions test it dosent pass in idle but it passes in 2500 rpm's it also has a dc sport header smog legal but the exhaust is a unknown brand and missing the resonator would this affect it at all.no trouble codes no bad smells just high hydrocarbons at idle ,thank's for you're time
Old Feb 19, 2007 | 10:31 PM
windcalmer's Avatar
Default RE: adjusting valves on 1998 civic ex
So what does this have to do with adjusting the valves?
Old Feb 19, 2007 | 11:17 PM
INJENalltheway's Avatar
The resonator doesn't do anything but quiet the exhaust down. And for your emmissions problem, I would start by cleaning the IACV.
cat287b
Mar 20, 2012 03:35 PM
honvic
Sep 2, 2011 09:49 PM
Tayz588
Nov 17, 2008 09:21 PM
greencivic
Feb 20, 2007 08:13 AM
