advice on replacing water pump
Old May 23, 2010 | 08:44 PM
lostforawhile's Avatar
gave up for the night, it's not the heat it's the humidity, you can go out there for ten minutes and the sweat is pouring off of you, it's like working in a sauna.
Old May 24, 2010 | 02:30 AM
catwalk7382's Avatar
How does mean that my friend. You clearly are not
Old May 25, 2010 | 04:27 PM
????? about to go finish setting the valves and get the valve cover on, get it started then change the oil
Old May 26, 2010 | 04:14 AM
SilverSedan's Avatar
How did everything go?
Old May 26, 2010 | 06:09 PM
I'm about to walk to walmart and get some distilled water, so i can fill the cooling system, you don't want water with minerals mixed with your coolant, it eats the crap out of aluminum. just been one stupid thing after another. I need to fill the system, then it has to be run for a few minutes, then the crank bolt gets turned another 30 degrees. entire new procedure on torquing that bolt from Honda.
anyone know if the adjuster screws for the valves can be replaced themselves? I'm thinking thats part of the valve tappet itself, some dumb **** tried to adjust these valves before I got the car and half the adjuster screw heads are stripped.
Old May 26, 2010 | 07:49 PM
really? I just did mine in Feb, had no idea about it. (T-belt and water pump). should be ok though.
Hope you get things sorted. I'd be pretty upset if I had to try to fix stuff like that - when its been screwed up by someone who didn't know what they were doing!
Old May 26, 2010 | 09:58 PM
the new procedure is:
first torque the bolt to 140 foot pounds, now loosen the bolt fully, remove the bolt and put oil on the bolt as per the service manual, (that's another overly complicated thing) torque the bolt to 20 foot pounds, now mark one of the points on the bolt with white paint and mark the pulley 60 degrees s from it, tighten the bolt until the mark lines up with the 60 degree mark. install accessory belts, and run the car at idle for at least 3 minutes, now tighten the bolt 30 more degrees for a total of 90 degrees.
flcb7
Nov 3, 2010 05:21 PM
ELLAS1945
May 25, 2007 08:04 PM
jjgarcia
Aug 22, 2004 07:39 PM
