all wheel drive crx conversion
Old Jan 21, 2009 | 09:11 PM
mattomatic's Avatar
Default all wheel drive crx conversion
hey guys, i have been on a few general honda tuner forums, and decided to try this civic only forum. i have a 91 crx base model. i have the chance to buy a non running 88 civic wagon with all wheel drive for cheap. i was wondering about converting my crx to all wheel drive. i know i would need a custom drive shaft because of the difference in wheel base. i need to know if the 88 wagon has the same side to side wheel base for the front and rear axles, and how much of a pain in the *** the conversion would be. also what other engines would the tranny and stuff from the 88 match up to, if i decide to upgrade engines later. thanks guys, any and all info would help me out.
Old Jan 21, 2009 | 09:24 PM
jpnolan's Avatar
I think engine wise it should bolt up to most d series. I would defiantly buy the wagon, I actually want to do the swap you speak of. I think the wheels base is the same im 90% on that, make sure you google it though to make sure. Good luck to you sir.
Old Jan 22, 2009 | 03:22 PM
SPLAT's Avatar
I hope you know there is going to be a lot of fab work.
But there have been a lot of people saying there are or thinking about doing this swap.
I hope you really do it and finish it.
Old Jan 22, 2009 | 04:10 PM
xsteinbachx's Avatar
You might want to create an Account at Revscene and check out this post. The guy is fabbing an AWD CRX.
http://www.revscene.net/forums/showt...&highlight=awd
Old Jan 22, 2009 | 06:33 PM
GReddy_Civic's Avatar
Snail'n Admin
Moved, there was an EF hatch that had the AWD platform, made some awesome power on a stock motor without blowing up
Old Jan 22, 2009 | 08:25 PM
ef9101's Avatar
any d series or b16 or 18 will work on that tranny the wheel bases is omost the same little of difference hope u go through with the swap its all worth it
some fabricating is needed
around at most 1500 if u do it all yourself
switch the rear drums to disc too good luck heres a ee9 with one done
let me no if u no ne one else with a wagovan i want this swap so bad
http://www.youtube.com/watch?v=PNN7M...layer_embedded
Old Jan 23, 2009 | 01:53 PM
mattomatic's Avatar
thanks for the replies people. i have done some research online, and so far all is good. hey xsteinbachx i looked at your link to the conversion and have created an account, i will follow it closely. the guy accepted my offer for the wagon. i am starting to strip it this weekend. i will keep all posted. any more replies are always welcome.
Old Jan 26, 2009 | 05:01 PM
mattomatic's Avatar
awd 88 wagon on the way this weekend, then the gutting begins. in the meantime, keep the d16a6 or upgrade to what? mini me swap, b-18, suggestions? can anyone recommend a good place to get performance parts that won't bust my *****?
smilleeguy
Sep 1, 2010 11:28 PM
Civi23
Mar 7, 2007 04:32 AM
Jeremy102579
Mar 21, 2005 10:47 AM
