Almost unbelievable
Old Oct 19, 2005 | 03:10 PM
aquessada's Avatar
Default Almost unbelievable
Dear Friends,
I have a civic 93EX AT d16Z6. At the end of 2004 i rebuidl the motor.
But, till now, we don't discover a nasty problem. The motor is pretty fine and the ignition points are pretty correct. Pretty sure.
But there is no idle. IT doesn't get an idle speed superior than aprox.: 150 RPM!!!
I try to accelerate, but it stalls and doesn't get power from the motor, and when it gets in move, everything goes fine till i have to stop the car and try to keep it alive!
All spark plugs are new. All the motor is new. There is no ECU code!!!
Could someone, for Godness sake, tell me what to do next?
Kindest regards,
Alex
Old Oct 19, 2005 | 03:33 PM
civicexracer's Avatar
Default RE: Almost unbelievable
my car did the EXACT same thing when i installed new headers. im not really to sure what could be causing it to happen but make sure ur car is breathing well and everything is nice and tight. also, check ur ECU and make sure everything is running properly. dont really kno what else to tell u except, good luck! hope everything turns out o.k.
Old Oct 21, 2005 | 10:22 AM
aquessada's Avatar
Thanks,
but, tell what you did to fix it! because i am REALLY insane.
Please, describe it to me..
Alex
Old Oct 21, 2005 | 11:16 AM
SkItZiAnIsT's Avatar
maybe you damaged your pre-cat o2 sensor (top one)
Old Oct 21, 2005 | 04:51 PM
aquessada's Avatar
Oh no, which one do you mean? the one just at the exhaust, near the oil meter?
Old Oct 21, 2005 | 05:06 PM
Remmy's Avatar
Its just a sensor, under a $50 fix you can do yourself. You also might need to get your idle re-adjusted. Here is another tip that you could try, simply disconnect your battery for 30 minutes to reset your ecu. THen reconnect the batery and fire up, it might solve your problem.
Old Oct 21, 2005 | 06:52 PM
AgentofDarkness's Avatar
If its an 02 sensor, if u disconnect the sensor, shouldn't the computer run in open loop and not use any 02 sensor readings? Maybe you should just disconnect the 02 sensor and see if it fixes the prob. Also, next time it stalls (or you could make it stall) spray some carb cleaner in the throttle body/intake. If it starts up again, then u can be sure its the fuel and not the air.
trustdestruction
Jun 25, 2009 08:21 AM
lowlife9
Mar 18, 2009 04:34 AM
Civic|UnLimiteD
Aug 24, 2007 02:36 PM
CocoaBrown
Mar 13, 2005 06:59 PM
94VTECoupe
Feb 8, 2005 11:31 PM
