auto transmission
Old Sep 19, 2009 | 11:05 AM
xpdude's Avatar
Default auto transmission
is it normal to have some clutch material stick to the magnate? i bought one with 90k from the junkyard and it still had burned fluid like mine. i am gonna swap it out again for another.
Old Sep 19, 2009 | 11:15 AM
not for a "90k" trans. yea i would swap it for another.
Old Sep 19, 2009 | 12:20 PM
xpdude's Avatar
Default trans
ok, so when you drain the fluid nothing should be on the magnet and if their is its screwed?
Old Sep 19, 2009 | 03:50 PM
There will ALWAYS be stuff on the magnet, but the "burned" fluid is a bad sign.
Old Sep 19, 2009 | 07:51 PM
xpdude's Avatar
Default tranny
ok, so SOME stuff will be there when you drain and fill? what about the grey clutch material? if it don't have burned fluid, and has that, is that good?
Old Sep 19, 2009 | 11:47 PM
he is talking about the grey material on the magnet. a bad sign is burnt fluid and/or metal shavings.
Old Sep 21, 2009 | 09:46 AM
xpdude's Avatar
Default auto swap
ok, so this car was totaled out and rearended and the trans had 60k on it. i drained the fluid it looked cleaner on the dibstick but it was dark red when drained and didn;'t smell burned. how do you drain the t.c and how do you remove the shift cable from behind the converter? their was little metal flakes w. grey color on the magnet but i didn't note any chunks in the fluid. is this one junk too? i think these cars are just peices of junk period! lol
Old Sep 21, 2009 | 09:57 AM
It sounds like it should be OK. The only way to know for sure is to put it in a car and drive it. The seller has a guarantee on it, right?
Old Sep 21, 2009 | 11:00 AM
xpdude's Avatar
yea it has a 90 day warrenty. but if it has metal flakes and friction matrial on the magnet, it isn;t gona last too long. is that right? also how do you remove the (turbine mainshaft speed sensor) and i wana drain the t.c converter.
Old Sep 21, 2009 | 12:26 PM
The torque converter doesn't just slide out?
