Automatic Transmission Fluid Dipstick awful loose
Old Jan 17, 2016 | 11:05 AM
Medic190's Avatar
Hi I found out how to fix this problem, so what you do is you take an O-Ring and you put it on the second Ridge of the upper black part where the dipstick top is located. It seals it shut. Worked on my 02 civic
Old Jan 19, 2016 | 07:55 PM
Ska-T's Avatar
My 1996 DX auto transmission dip stick was loose when I first got the car about 10 yrs ago. I tried the o-ring trick but not with much success. I replaced the dip stick with a genuine Honda part and it fit nice and tight. Now it is loose again, but not quite as loose as before.
Old Feb 9, 2016 | 03:23 PM
jonsey1886's Avatar
The rubber that sits on the top of the dipstick deteriorates over time, reinforce it with some duct tape, an o-ring or a small washer.
Or just be resigned to buying a new dipstick every 6-10 years.
Old May 6, 2017 | 06:31 PM
Joshua Ryan's Avatar
Default Dipstick
i just fixed my today with a simple gromit from advance auto.. Now its in there snug
Old Jun 14, 2017 | 06:44 PM
Duane4238's Avatar
Easiest and best fix is a new dipstick from Honda. It seems the rubber seal that's on there shrinks and deteriorates over time. A rubber band or an O-ring could lead to bigger problems if a piece of one of them finds its way into your tranny.
Duane
enigma34
May 13, 2009 06:41 PM
beagler
Mar 31, 2009 09:28 AM
01silverbullet
Jun 12, 2008 09:28 AM
crimsonnblue
Feb 28, 2008 08:10 AM
truckmsl
Aug 12, 2007 01:20 PM
