B16 reving Problem. Need help
Old May 23, 2007 | 04:52 PM
nightrider46's Avatar
Default B16 reving Problem. Need help
I have a JDM b16 with the p30 ecu swap in my 97 civic dx and When i have my car in neutral or even in drive, i cant rev past 4k rpms. Why is it doing this and How do i fix that?[/align]
Old May 24, 2007 | 11:30 AM
glada96EX's Avatar
Default RE: B16 reving Problem. Need help
Either the vtec is wired wrong, or you dont have enough oil in it. Check all your fluids, and if everything looks fine, check your wiring for the vtec system. I assume you did the proper procedures and wired the vtec to the ecu?
cbaber's Avatar
Who did the swap? Where did you get the motor from? If some shop did the swap I would be asking them.
Old May 24, 2007 | 11:56 AM
I did the swap myself but i'm not good with the wiring section. I hooked up the vtec solenoid and the vtec oil pressure has 2 wires one goes to pinout D6 and the other one i'm clueless, but i think it's a ground but where does that ground go?
cjy01
14
Jul 10, 2011 03:38 PM
civic_turbo
Mar 7, 2008 09:03 AM
H22
Nov 20, 2006 05:46 PM
RoundEyeRacing1904
17
Aug 3, 2006 11:40 PM
Zer0Ale
Jul 20, 2006 12:48 AM
