b16 swap no start
i just got a b16 swap, i put it into my 94 civic and i cant get it to start...i have fuel coming out the injectors. i have spark at my plugs. but it doesnt sound like i have compression.... what should i check? should i do a compression test? iv been told to adjust the valves, and i tryed but im not sure if i did it right. im just really frustrated...any help would be appreciated
Yes, test the compression. Make sure the cams are in time. Check the firing order, when you set the engine to TDC1 take the distributor cap off and see that the rotor points to wire #1. Make sure the rocker arms are slack when the valve is supposed to be closed.
alright i will check all that tomorrow and let you guys know. i just adjusted the timing belt because it was a tooth off and now its perfect...ill check the valves and dizzy tomorrow though..thanks
David_S
Oct 24, 2013 10:06 AM
turbo speeder
Jan 28, 2009 03:57 PM
