b16 vtec vs gsr vtec
Old Jan 2, 2007 | 11:33 PM
b8teen's Avatar
Default b16 vtec vs gsr vtec
i ran a search but couldnt find anything. im getting ready to put together a ls/vtec motor. i have a ls in my hb, and was wondering wgat the differences were in the heads. is there any diff between the 1.8 gsr head and the 1.6 si head. do i have a choice? what are the pros and cons between the two?
Old Jan 3, 2007 | 07:26 PM
sacicons's Avatar
Default RE: b16 vtec vs gsr vtec
gsr has higher compression, b16 flows better. they pretty much even each other out.
Old Jan 3, 2007 | 11:46 PM
b8teen's Avatar
so if i were to get a b16 head, it would need to be the same obd system and in the same generation af my ls right?
Old Jan 4, 2007 | 08:00 PM
sacicons's Avatar
that would be easiest.
Old Jan 4, 2007 | 09:33 PM
ef4life's Avatar
i thought the b16 had more compression. the b16 head is the same casting as a type r head.
Old Jan 4, 2007 | 10:23 PM
Kedawei's Avatar
It's kind of like the Y8 and Z6 heads I think (since you seem to be a D-series guy). The B16 is round and flows better, and the GSR has squared chambers.
Old Jan 4, 2007 | 11:14 PM
b8teen's Avatar
what would be the most efficient head to use on the 93 ls?
Old Jan 4, 2007 | 11:20 PM
Kedawei's Avatar
With a proper port job ($) the GSR head will be better. Depends on your budget. The B16 head will do a great job without work needed.
Old Jan 4, 2007 | 11:56 PM
b8teen's Avatar
can anyone give me a detailed parts list for the b16 head? i know that ill need the dizzy, and the ecu, but waht else? or can someone give me a websit to look at. thanks
turbo speeder
Jan 28, 2009 03:57 PM
sonicwagon
12
Feb 16, 2008 04:39 AM
johnny
May 13, 2007 07:23 PM
djmatix
Oct 13, 2005 10:19 PM
