b16a2 94 Hatch Broken Coolant Bleeder Screw
Old Feb 2, 2012 | 06:29 PM
phoenixsageroger's Avatar
Default b16a2 94 Hatch Broken Coolant Bleeder Screw
JDM b16a2 installed on a 94 Civic Hatch CX 60k
Someone has snapped the coolant bleeding valve from the "water outlet cover"?
Quick valid questions please:
Question 1: What is this part called for my b16a2? Where can I get it replaced? Is it easy to remove this assembly? I havent had a great look at it on the backside of the motor. Been dealing with 100 other things.
Question 2: I have the bleeding screw and the little housing it threads into. Can I glue , weld or attach this back onto the block? Looks to be the similar material as the engine. Cement block material stuff?
I temporarily have a screw lightly twisted into the hole.. Seems it holds the coolant under pressure.. I dont want to rely on it. I keep checking it every so often while driving.. Dont want to hit high RPMS much.
How do i permanently repair?
Any advice would be helpful.
Also looking to buy the "water outlet cover" for a b16a2, or whatever it is called.. Is this the correct term?
Thank you in advance.
Old Feb 3, 2012 | 05:58 AM
Welcome to the forum.
Is this on the upper radiator neck on the motor? Can you post a pic?
Old Feb 3, 2012 | 06:33 AM
Look up the parts using a car model that had the B16 stock. I would think that part is the same be it JDM or a USDM Acura.
Old Feb 3, 2012 | 02:59 PM
Hey thanks a bunch. I really do appreciate it. I will try to share what knowledge I have as well.. Let me know if you need anything
csc67
Jun 4, 2011 02:05 PM
isup
Feb 11, 2009 06:13 PM
that_guy5
Feb 3, 2007 08:27 PM
jonyg98civicex
Apr 6, 2006 08:09 PM
alan4359
May 18, 2005 07:51 AM
