b18b1 into eg help?
Old Apr 1, 2011 | 10:35 AM
whiteg0rilla's Avatar
Default b18b1 into eg help?
so i want to get this b18b1, its a full swap for like 450. that a good deal? well the only problem is that its an automatic,i dont feel like dealing with finding a new tranny and all that stuff...so is it possible to put this into my 94 civic thats a stick shift? is it worth it? what parts would i need? thanks for all replys
Old Apr 1, 2011 | 05:14 PM
anyone? im trying to get the swap this weekend if it will work
Old Apr 5, 2011 | 09:02 PM
elperdido's Avatar
Well the sweet thing about Civics is that almost all of the chassis is the same whether it is stick or automatic. This is because Civics when manufactured have all three holes for the the pedals, but if it is automatic, they just put the plastic to cover the hole eventhough it is stil there. For $450 if the motor is perfecting and running it is a good deal. As far as the swap, since you would be switching fromstick to automatic you will need new wiring and ECU since there is a sensor that know when the clutch pedal is down so your car can turn on. Beides that just motor mounts, if all else is included. Whether the swap will be worth it or not is going to be up to you. If you want to keep the car and just cruise with it then that would be just fine. If you are looking to seel it down the line, then the swap might not be worth it simply because most would prefer a stick shift swap so they would end up not giving you as much as you will be asking for. It all depends on what you want to do. Good Luck with the swap!!
91hatchyb18
ED-EF Swaps
Apr 26, 2011 09:17 AM
hondahead21
Nov 9, 2010 12:46 PM
JDMRDCiViC95
Jan 14, 2007 02:38 AM
sleepin stock
EK Swaps
Sep 28, 2006 02:16 PM
logic0010
Mar 23, 2005 11:05 PM
