back from the dead with a serious problem
Old Apr 3, 2011 | 07:43 PM
DrewUSARMY's Avatar
Default back from the dead with a serious problem
so some of you know i have a 90 dx hatch with a non vtec ls swap
i have already done the mpfi conversion and i cant seem to get it started
it turns over and im getting fuel to the rail but im unsure if im getting fuel through the injectors
im pretty sure im getting spark because i already replaced everything in my dizzy.
Old Apr 4, 2011 | 02:55 AM
Check the spark for sure. Also check the cam timing and firing order. Don't assume that anything is good at this point, go through all the "cranks but won't start" checks from the beginning.
When there's no signal from the distributor, the ECU doesn't know that the engine is turning, so the injectors won't fire either. You can check if it is trying to pulse the injectors by unplugging one and putting a #194 bulb in the plug. The bulb should flash when you crank.
Peg_Leg
XBox/XBox 360
May 7, 2010 06:42 PM
AnimalWild
Jun 27, 2008 11:46 AM
megafandrew
Feb 24, 2008 06:53 PM
Oefarmy2005
Sep 26, 2007 03:37 AM
