Ball joint
Old May 18, 2007 | 12:14 PM
BrianT's Avatar
Default Ball joint
Does any one know how to move the LBJ so i can swing the brakes around that way a can replace my axel?
Old May 18, 2007 | 02:07 PM
AOL.COM's Avatar
Default RE: Ball joint
loosen up the ball joint nut till its almost off -
then get a BIG hammer (i use a 2 1/2 lb sledgehammer )
wack the lower control arm where the ball joint goes thru , a few times to free it up, take the nut off (leaving the nut on a little saves you the trouble of replacing the ball joint cause when you swing n miss with the hammer & hit the ball joint stud & wipe it out - been there - done it)then just lift up the spindle assy
Old May 19, 2007 | 05:03 AM
BrianT's Avatar
thanks
Old May 21, 2007 | 04:12 AM
It's a lot easier if you just go to autozone and rent one of these...
SiX
May 2, 2007 12:20 AM
DenzComp
Oct 11, 2006 12:54 AM
DenzComp
Oct 1, 2006 10:25 PM
anthony_delprete84
Aug 9, 2006 09:11 AM
Unc0ntr0l
Apr 17, 2006 03:26 PM
