battery light won't illuminate
Hi.
I'm trying to track down an alternator issue.
I read that if I ground the white blue wire on my 4 pin plug, my battery light should illuminate.
I cannot get my battery light to come on. With the key to ignition, it doesn't come on. I can't figure this out. What's my next step?
I'm thinking the white blue wire has a short but I'm unsure where the wire runs to. Should I have continuity from white blue on the alt plug, all the way to the cluster white blue wire?
That's no good, you need to have full 12 volts there. It is very likely the fuse is blown, or there is a problem with the harness such as the fuse 15 problem of 1996-2000 models.
The white-blue wire simply goes to the cluster and thus to the bulb. The other side of the bulb is powered from the same circuit that powers the black-yellow wire.
The car in question is a 1990 civic dx.
I am trying to find a pinout at the moment. The black yellow wire terminates at the shock tower connector. It has continuity with the thick yellow wire.
The issue is with my engine harness
milhouse
Sep 26, 2013 05:31 PM
2468wdya9
Dec 14, 2012 10:48 AM
Knobmeister
Apr 14, 2012 05:47 AM
Ki_Ryn
Jun 26, 2009 06:42 PM
addiction2bass
Jul 24, 2006 08:57 PM
