Battery and Oil light come on, car dies
Old Apr 27, 2013 | 07:55 PM
windsor's Avatar
Default Battery and Oil light come on, car dies
I have a 98 Civic CX 5spd. manual. I finally changed the instrument cluster out for one with a tach. I disconnected the battery to do this so I would have no way of doing something bad with the airbag. Started it up, worked fine for a minute or two, but when I got to a stop and had the clutch depressed and the brake on, the battery and oil light came on and the engine died (no CEL on). I got it back to the house by figuring out that if I was giving it a little gas, that the RPMs were up and it wouldn't die.
I changed back to the original cluster, and that didn't do anything. I checked the battery and alternator, and all of that seems fine. I can hear the fuel pump start when I turn the car on. Checked the oil and it's OK...maybe a little more than needed, but still OK. Any thoughts?
Old Apr 28, 2013 | 06:35 AM
After disconnecting the battery on an OBDII, you need to drive and idle for a while to let the computer recalibrate itself.
If the problem persists, it sounds like an IACV problem since the only problem is that the car won't idle.
The oil and battery lights normally come on whenever the key is on but the engine is not turning or is turning very slow.
Old Apr 28, 2013 | 07:19 PM
windsor's Avatar
That was it! Thanks. I've driven it more today and it seems to be idling fine now.
mxpx4182
Aug 13, 2014 05:51 AM
drewrussell2011
May 17, 2014 07:57 PM
oilltd
Jun 10, 2008 04:06 PM
Bartacus
Apr 15, 2005 03:29 PM
