Brake Problem
Old Aug 8, 2010 | 10:14 AM
rhino351's Avatar
Default Brake Problem
I have a 94 Honda civic and whenever I stop at a red light, the brake pedal slowly sinks down and eventually gets to the floor after a couple minutes. Its stiff other than that, and its definitely not leaking any brake fluid. Any ideas?
Old Aug 8, 2010 | 10:16 AM
Replace the master cylinder, it has an internal leak.
Old Aug 8, 2010 | 04:25 PM
honda_farmboy's Avatar
Banned
It's a pretty easy job too. And when you try to pry the master cylinder off of the booster, make sure you pump the brake a few times with the car off to relieve the pressure.
Old Aug 9, 2010 | 05:13 AM
rhino351's Avatar
Thanks, I'll try that then. It's the master cylinder even though the fluid level in the reservoir never changes?
Old Aug 9, 2010 | 07:49 AM
Yes this is very typical of a worn-out master cylinder. The piston inside has fluid on both sides. One side is at high pressure driving the calipers, and the other side is low pressure basically connected to the reservoir. So as fluid leaks past the piston the pressure decreases, causing the pedal to move down. No fluid is lost to outside though.
This situation will get worse and worse until ultimately it can't build any pressure at all and you won't be able to stop.
Ed Fisher
Aug 20, 2009 11:47 AM
Cosworth
Dec 15, 2008 05:35 AM
burgernuds
18
Aug 16, 2008 07:20 PM
j2performance
Jan 15, 2008 01:48 PM
Stumasters
Jan 17, 2007 01:36 AM
