Brake Problem
Old Nov 9, 2010 | 06:29 AM
maachan513's Avatar
What you see with wheel(s) off should be the drum(s). The drum should come off with pulling motion. I don't think there are, but make sure, there are no retaining screws on your drums. Light tap with hammer may do the trick. If it is hard to remove, there shall be threaded holes on the drum. Find extra bolts with correct threads and screw them in little by little with even turns. You should see the drum moves as you turn them bolts in.
Hope this will help.
Old Nov 9, 2010 | 07:38 AM
Possibly the parking brake cable is stuck. Inside the car, take off the trim around the brake lever so you can see the ends of the cables. There is one on each side of the car. They should go in and out the same as you pull the lever up and down. If the one on the left doesn't move, it is probably rusted up and needs to be replaced. If you can't get it to move at all, and you can't force the drum off using bolts, cutting the cable near the wheel should release the brake so that you can get the drum off and put a new cable on.
Old Nov 9, 2010 | 08:09 AM
chiles400's Avatar
Banged it with a hammer and it loosened. Thanks for input.
john
Old Nov 9, 2010 | 10:51 AM
maachan513's Avatar
Bigger hammer works better than small ones, on some applications. And this was one of those applicatons ,,,
Ed Fisher
Aug 20, 2009 11:47 AM
Cosworth
Dec 15, 2008 05:35 AM
burgernuds
18
Aug 16, 2008 07:20 PM
j2performance
Jan 15, 2008 01:48 PM
Stumasters
Jan 17, 2007 01:36 AM
