Brakes Issue
Old Jul 16, 2008 | 08:34 AM
Brookshadow_RC's Avatar
Default Brakes Issue
New to the forum. I have a 93 Civic and last week the brake pedal started going soft. Then, it went to the floor and stopping was scary. I have checked and there appears to be no loss of fluid in the master cylinder. I have checked all 4 wheels and no visible leaks? What could this be? Any ideas? Thanks in advance.
Old Jul 16, 2008 | 08:45 AM
Default RE: Brakes Issue
Soft brake pedal + no fluid loss/leak = bad master cylinder (generally)
You might try bleeding the hydraulic system of possible trapped air first, though I think a new master cylinder is your final destination.
Old Jul 16, 2008 | 09:19 AM
Yes your master cylinder is worn out. Rest of the system should be OK. Check that brake fluid from the master cylinder didn't get into the brake booster, because that will cause the diaphragm in the booster to blow out in a few months.
Old Jul 16, 2008 | 09:27 AM
Also it could be because someone put a substance other than brake fluid into the reservoir. The entire system is destroyed then.
Old Jul 16, 2008 | 04:47 PM
Smokin94civic's Avatar
rear brake pads being wore will also give you a soft pedal an make it gotto the floor, may want to check those as well
Old Jul 16, 2008 | 05:39 PM
I had the same thing happen in my old 92. Master cylinder was worn out.
Old Jul 16, 2008 | 06:25 PM
a blown seal inside of the master cylinder will not cause the system to lose fluid but will cause the pedal to go to the floor. you need a new master cylinder. i had the same exact problem.
mudhenFUF
Jan 16, 2023 08:43 PM
jonsaidthat
May 30, 2010 09:30 PM
ahhsimon
Jun 14, 2006 09:52 AM
faceless_civic
Nov 17, 2004 10:19 PM
