A/C causes engine surging, alt light to come on
Old Jun 15, 2012 | 12:32 PM
GenePro's Avatar
Default A/C causes engine surging, alt light to come on
Baffling... sporadic but frequent problem: 2002 Civic EX, manual trans, 110,000 miles. Often when A/C is switched on, the engine surges between 300-2000 rpm at idle, sometimes stalling. When this happens, the A/C is not cooling - fan is on, but not cooling. No surging occurs unless the A/C is switched on. Sometimes all systems work fine. Can't cause the problem show up. Neither Honda dealer service nor an independent shop has been able to diagnose. Maintained in great condition other than this problem. Any clues, anyone?
Old Jun 16, 2012 | 09:49 AM
While it is acting up, check that both fans under the hood are running. If the fans don't work, the A/C condenser in front of the radiator will overheat, leading to over pressure which bogs down the engine.
If you can press the gas pedal slightly and have good A/C performance, with both fans running, clean the IACV valve on the intake.
Jordan31
Jul 9, 2013 12:32 PM
Knobmeister
Apr 14, 2012 05:47 AM
Viral Sanchez15
Aug 7, 2010 12:10 PM
93SiHb
Sep 10, 2005 01:34 PM
triggerstep
Dec 16, 2004 12:00 PM
