A/C Compressor Exploded...
Old Aug 13, 2009 | 12:21 PM
Adrenojunky's Avatar
Default A/C Compressor Exploded...
Ok - well I was driving home yesterday, and I could hear one of my belts starting to sqeal a-bit. It's been doing this every now and then lately. Well, all of a sudden I heard a something hit my firewall and/or hood, and heard some stuff falling out of the engine compartment. I figured I'd thrown/shredded a belt since my A/C went warm. I hurried home cuz I figured I may have lost an alternator and/or water pump belt (never looked to see how the accessories were configured). When I got home, I looked under the hood and saw a bunch of chunks of aluminum under my A/C Compressor - along with plenty of loose A/C system oil. So, basically my compressor exploded. It appears as if the bottom blew out. I've never heard of this, but after searching online, I guess it's relatively common.
So, I guess I'm wondering what exactly I need to replace here. I'm shooting for just the compressor, as I'm pretty short on cash. I'm asking because some folks on some other websites have had similar problems, only to have the dealer/mechanic replace the entire A/C system. This seems quite excessive to me... I know contamination is a concern, but is it really a $2500+ concern? I'm a seasoned mechanic, but rarely have I dealt with A/C systems. Does anyone see a problem with me simply replacing the compressor?
Old Aug 13, 2009 | 12:36 PM
zsatbecker's Avatar
psh.
where do you live?
you dont need ac. hahaha
Old Aug 13, 2009 | 01:14 PM
Originally Posted by zsatbecker
psh.
where do you live?
Phoenix - so yeah, when it's 118 deg out, A/C is pretty much mandatory...
Old Aug 13, 2009 | 01:22 PM
just replace the a/c compressor and check all your lines.. refill new compressor with 1 6oz pag oil then turn off engine let sit for 30mins and then refill with r134a use a guage and dont over charge.
Old Aug 13, 2009 | 03:36 PM
GReddy_Civic's Avatar
Snail'n Admin
hmmm hopefully ronj will chime in, but i have an ac condensor from my 97 civic
Old Aug 13, 2009 | 10:08 PM
just replace the a/c compressor and check all your lines.. refill new compressor with 1 8oz pag oil then turn off engine let sit for 30mins and then refill with r134a use a guage and dont over charge.
Cool, thats what I was thinking...
Old Aug 14, 2009 | 05:21 AM
Replace the condenser. When the belt started squealing, that's because the compressor was tearing itself apart inside. Most of those bits are now in your condenser, and they are almost impossible to remove from the small passages. Also the receiver-drier must be replaced with any major service, it is an expendable part like an oil filter.
Oil capacity of most Civic A/C is 4 oz -- too much oil is bad. Also you must evacuate the air from the lines with a vacuum pump before recharging.
Edit: Also the compressor is the most expensive part; it costs less to replace everything once than to replace the compressor twice. Especially if you have a pre-2002 model it does not cost anywhere near $2500 to replace everything.
pwonder88
May 16, 2012 04:10 PM
20 SMOKE
Mar 8, 2012 06:04 PM
gsrgofass
Oct 22, 2007 07:03 PM
MichiganRice22
Mar 23, 2006 05:00 PM
jim9418
Dec 16, 2005 02:01 PM
