a/c goes low
Old Sep 17, 2007 | 09:03 PM
rutabegar's Avatar
Default a/c goes low
I have a 98 Civic CX. On long distance drives, often the a/c stops blowing. I can feel cold air trickling out very lightly, and if I turn the fan all the way up, it makes a lot of fan noise, but no air is blowing in. If I turn it off for 10 minutes or so, the fan kicks in again, and it works fine. After three or four hours, it happens all over again.
Any ideas about the cause of this?
Old Sep 18, 2007 | 04:15 AM
Default RE: a/c goes low
The evaporator coil inside the car is getting too cold. This coil works like a heater core in reverse, the fan blows air thru the fins on it and the air is cooled. Normally it condenses water out of the air and the water drips out under the car. When it gets too cold the water will turn to ice instead and cover the fins on the coil until it reaches the point where air can't flow thru it.
After you turn the A/C off for a while, the ice melts and airflow can resume. There is a sensor to automatically shut down the compressor before the evaporator gets too cold, appears it isn't working.
sebdiz
Apr 28, 2010 05:45 PM
boostphreak
Aug 27, 2008 11:15 AM
H22CIV
Sep 27, 2006 01:13 PM
liliechen
Dec 25, 2005 11:15 AM
icarus
Nov 21, 2005 08:32 PM
