a/c not working
Old Jun 13, 2008 | 09:59 AM
melaniem's Avatar
Default a/c not working
I did the dtc test and it is my circuit blower. how do I fix it?
Old Jun 13, 2008 | 01:03 PM
Default RE: a/c not working
Your interior fan doesn't work then?
Turn the fan on high and measure the voltage between the two pins on the blower motor, which you can reach by looking up from the passenger's floor. If you have 12 volts there but it's not running, the motor is bad. If it's zero check the fuse under the hood. Finding the fuse good you probably need the power transistor module.
Old Jun 17, 2008 | 10:03 AM
melaniem's Avatar
thank you.. I'll see if that works
chloiebear21
Dec 24, 2012 11:46 PM
Juans_MX3
Apr 7, 2010 03:38 PM
gunaa
Oct 22, 2009 11:36 AM
chrisroug
Oct 2, 2006 11:36 AM
lukbrw
Jun 9, 2004 01:36 PM
