A/C Not Working
Old May 20, 2013 | 10:16 AM
Don't_Know_Jack's Avatar
Default A/C Not Working
1996 Honda Civic Dx
Whenever the A/C is turned on, it immediately blows the fuse (20A).
Testing the Condenser and Comp. Clutch Relays by jumping each one narrowed it down to the Comp. Clutch.
The Compressor will not turn by hand.
Help would be appreciated.
Old May 20, 2013 | 11:55 AM
Sounds like the compressor is shot if it is not spinning by hand. I can spin mine with no problems. Not an a/c expert by any means though.
Old May 20, 2013 | 02:00 PM
civicinin's Avatar
I'm no a/c expert either, but I did remove my a/c compressor from my 2001 Civic LX. I think it also was having trouble turning. So if you get to the point where you want to remove it, I might be of the slightest help.
Old May 20, 2013 | 03:31 PM
Sounds like the bearing failed and burned out the clutch coil. A good Civic compressor turns easily by hand. There is a "once around" clunk in the scroll mechanism but it still can be turned by hand.
chloiebear21
Dec 24, 2012 11:46 PM
Juans_MX3
Apr 7, 2010 03:38 PM
gunaa
Oct 22, 2009 11:36 AM
chrisroug
Oct 2, 2006 11:36 AM
lukbrw
Jun 9, 2004 01:36 PM
