A/C PROBLEM & A NOISE WHEN IT STARTS UP HELP!!!
My a/c is just not blowing cold. I had the compressor changed and put freon in it. I had it drained and refilled because I thought it had too much oil, still not cold enough. I dont know what it is. its like the temperature is not being reached to cool the car inside just blowing heat. Its only cools once the sun goes down, but thats not normal. Could it be a block in a line? Any tips? I need help before going to a shop and getting overcharged.
Also out of nowhere I hear this strainning noise when I crank the car. it sounds like me turning the key back to hard (errr) I tried turning it lighter but I still hear it. What could it be?
No leaks were found. The compressor was changed and the freon was drained and refilled. It's full of freon but still not cold enough. What could be blocking my air or making it not get cold enough??
I HAVE A 90 COROLLA THAT STAYS FREEZING. YOU TURN THE A/C ON AND ITS INSTANT FREEZING COLD NO MATTER HOW HOT OUTSIDE. I DONT KNOW WHAT'S WITH THE CIVIC IT NEVER GETS THAT COLD NO MATTER HOW LONG RUNNING, IT CANT BE NORMAL.
Part of the honda not being very cold is the fact that they dont use the best door seals on the civics. Mine does the same thing not very cold but it is cold none the less.
the hotter it is, the wamer its going to blow out. thats why it blows cold at night. when its 85 out with 50% humidity then it only has to blow around 70 degrees. a lot of people think its suppost to be freezing no matter what.
ORIGINAL: neon3kgt
ORIGINAL: civicraider
