A/C problems
Old Apr 18, 2019 | 05:57 PM
rasouth's Avatar
Default A/C problems
Hey everybody! I'm new to this forum and may not know exactly where to post my questions.
My problem is with a/c blowing hot air occasionally. When it works it blows out nice cold air, and then without warning starts blowing hot air. I have checked and replaced relays, checked fuse, fans come on even if compressor does not engage. I have checked all connections for continuity all the way to the field coil, loosened the green wire (ground, I believe) that is connected to compressor and moved it around in case it was a dirty contact. I get an OHMs reading if I touch my volt meter probe to battery ground and the other to the field coil wire going into coil. Does this sound like a bad clutch? Field coil? Adjust gap between clutch and field coil? The clutch does move freely if I try to turn it and does not make any squeaking noises.
cb526
May 8, 2013 11:36 AM
kthomas
Sep 2, 2010 06:43 PM
Frankc
Jun 29, 2009 08:13 AM
ohbiskits
Oct 20, 2005 09:45 PM
AgentofDarkness
Jun 30, 2005 07:02 PM
