Car at idle shakes alot:
Old Mar 26, 2008 | 02:42 PM
itgrowsind's Avatar
Default Car at idle shakes alot:
Do you know what may be causing the annoying amount of shaking the car does? The steering wheel vibrates alot as well
Old Mar 26, 2008 | 03:30 PM
macbeth18288's Avatar
Default RE: Car at idle shakes alot:
Could be something simple like poor alignment, a bad tire, etc.
Old Mar 26, 2008 | 04:11 PM
Are the idle rpms too low?
Old Mar 27, 2008 | 05:04 AM
93civicdx's Avatar
so your saying the steering wheel shakes at idle...if thats wat your saying then either your rpms are too low or you could possibly have a motor mount bad.
Old Mar 27, 2008 | 05:34 AM
1slowcivic's Avatar
Your subject says car shakes at idle, but you don't give us much information from there. What RPM's are you at with the car in nuetral/park? Does it have any difficulty with power? If your RPM's are lower you might have bad spark plug wires or plugs causing it to run on a three or missfiring. Low RPM could be fuel delivery, spark, or timing.
If your RPM's are normal you might have a bad, or broken motor mount but I would think you would notice that at all speeds. Some more info on when it shakes and what rpm it does it at would be helpfull.
Old Mar 27, 2008 | 06:18 PM
itgrowsind's Avatar
RPM's are at about half of 1 mark at idle!
Old Mar 27, 2008 | 06:43 PM
What year and model Civic?
Is the check engine light ON?
Try adjusting the idle screw on the throttle body. You might also have a dirty IACV or air filter.
Old Mar 27, 2008 | 07:35 PM
Type RB's Avatar
What year and how many miles?
You could have a bad motor mount, cylinder pressure imbalance, a plug not firing, idle too low, timing way off, or any combination of those.
Old Mar 28, 2008 | 06:24 PM
itgrowsind's Avatar
2000 Civic Ex miles=121,512
Old Apr 14, 2008 | 06:43 PM
TheJGB3's Avatar
Is this issue ONLY at idle? Does the carrun just like normal exceptat idle?
DO you have polyurethane motor mount inserts? I do, and I always have a vibration at idle (the steering wheel feels almost like a sewing machine)once the engine reaches operating temp. (RPMs are below 800)and it shakes even more with the A/C on (but it always goes away whenIget the RPMsup above idle). Sometimes when people ride with me (and we're idling somewhere), they say "you probably need plugs and wires because you have a miss"but I tell them no - it's because of the motor mount inserts which make the mounts essentially like a solid mount hence the vibration at idle. Ifyou have them like myself,you have three choices.
1. raise your idle a little (850-1000RPM, but will use more GAS)
2. remove the inserts (back to stock)
3. LIVE with the vibration (what I decided)
At your current mileage I would definitely change out the plugs, wires, cap and rotor, fuel filter, air filter, PCV valve, and set timing: basically a tune up(if you haven't already) and don't forget you should have done the timing belt and water pump at 105k.
If you do not have polyeurethane inserts, then maybe your idle is too low, bad gas, fuel filter, needs tune up, etc. like others have mentioned in this post.
chrisb18c1
Nov 29, 2011 04:37 PM
USMCDeAvilla
Nov 12, 2011 08:31 AM
Dee911
Jul 21, 2011 10:32 AM
garterberry
Jan 26, 2011 07:17 AM
mill$civic
Jan 19, 2006 01:08 PM
