89 Civic electrical problem. ADDITIONAL INFO
Old 08-12-2005, 11:53 PM
rick90yj's Avatar
Default 89 Civic electrical problem. ADDITIONAL INFO
OK, I got this thing at an auction. It's a four door 89 Civic with the four culinder and automatic transmission. The turn signals, tach, fuel gage and temperature gage work intermittently. The first time I noticed it, I was playing around with the transmission in neutral and while moving the shifter, basically, the left half of the instrument panel went dead. Also the turn signals quit working. According to the wiring diagram I have in my Haynes manual, they are all run off the same circuit. Has anybody run into this and solved it? Is there some wiring that runs by the transmission that the shifter could be pinching or messing up? HELP ! ! ! !
I forgot to mention, it runs good, and starts right up...I just can't drive it without the lights and gages...HELP
Old 08-14-2005, 08:08 AM
maachan513's Avatar
Default RE: 89 Civic electrical problem. ADDITIONAL INFO
Electrical problems are very hard to ttpubleshoot. Following the wiring diagram, I would look for loose wire, loose connection, burnt/ overheated connection, corroded connection and the like on affected system first.
spinjunkiee
07-16-2007 05:26 AM
lilrob
05-22-2007 02:23 PM
wjelmer
11-03-2006 10:19 AM
Kuttooz
05-05-2006 03:18 PM
tilstad
04-01-2006 02:33 PM
Quick Reply: 89 Civic electrical problem. ADDITIONAL INFO
