Car Wont Start
Old Dec 25, 2007 | 04:23 PM
DreamTeam87's Avatar
Default Car Wont Start
Before I just installed the new cd player in my car i worked fine not sure if that has anything to do with it or not but after that i wobut nt start it just turns over... I have fuel pressure and the car did start once but when i did it sounded really deep toned like it was running on 3 cylnders... could someone give me some suggestion on some thing i could check to see what the problem is? I also unplug the stero power to see if that would change anything but no
Old Dec 25, 2007 | 06:22 PM
Default RE: Car Wont Start
check spark plugs
Old Dec 25, 2007 | 11:21 PM
What year Civic?
Is the Check Engine Light ON?
If there is no spark at the plugs, then troubleshoot the coil and igniter unit in the distributor.
Old Dec 25, 2007 | 11:34 PM
Civic Si 00's Avatar
Maybe it can be a bad cap or rotor
Old Dec 26, 2007 | 04:55 AM
Check that you didn't blow the 7.5 amp "BACK UP" fuse in the fuse box under the hood near the battery. This fuse feeds power to both the ECU and the stereo. Though I don't think having it blow would cause a no-start, it might on some models.
Old Dec 26, 2007 | 12:02 PM
Its a 94 Obd1 and if it was the ignitor would the check enigine light come nd and throw a code 15 for ignition output? Well theres no check eniine light on so what could it be that wouldnt cause the enigine light to come on?
Old Dec 26, 2007 | 12:23 PM
ORIGINAL: DreamTeam87
I don't think that all igniter faults would throw a code 15. A faulty coil also would not necessarily not throw this code. See also suggestions by others.
David_S
Oct 24, 2013 10:06 AM
...NEED4SPEED...
Apr 20, 2010 03:55 PM
bmelloh
May 16, 2009 08:01 PM
niteryder
Dec 29, 2004 06:47 PM
89 pos
Jun 25, 2004 05:35 PM
