Car won't start!!!
Old May 8, 2010 | 09:08 PM
Melvinsaniac's Avatar
Default Car won't start!!!
I did retard the timing.
It has been sitting for a little while, but all the dome lights, CD player, ect.. come on.
It's a '96 Civic DX- manual trans.
Old May 8, 2010 | 10:18 PM
Does the starter fail to turn/crank the engine or does the engine crank but not start?
Old May 8, 2010 | 11:20 PM
It doesn't crank.
Old May 9, 2010 | 07:01 AM
1) Check whether the battery is low on charge.
2) Check the safety starter switch at the top of the clutch pedal. It might be bad or the rubber stopper has broken or fallen out.
3) Check the starter itself by wiring it directly to the battery when the transmission is in NEUTRAL. If it does not crank, the starter is bad.
4) Check the ignition switch.
dkd
Nov 30, 2020 07:38 PM
David_S
Oct 24, 2013 10:06 AM
forrealb50
15
Nov 12, 2006 01:52 PM
Smeghead009
Jun 1, 2005 07:46 PM
bek3k1
Mar 18, 2005 08:36 PM
