cat needed for o2 sensors to function?
I put a header on my car and now my car idles wierd. It'll sit and idle fine for a minute, and then drop suddenly to around 200rpm for 5 seconds, then it'll go back up to normal idleing rpm. Since I have a 2002 dx civic, the cat is connected to the exhaust manifold. And when I took it off to fit the header, I now have no cat. I'm throwing an o2 sensor code but I don't want to change it until o figure this out.
Which sensor code? The first sensor doesn't depend on the cat. It is possible for a sensor to break when you unscrew it and try to reuse it though so you may have a bad first sensor now anyway.
Put a cat on. I don't want to breathe your pollution. With a header you use an EX type cat under the car. The wires for the second sensor at the outlet of the cat will need to be extended, they sell a plug and play harness for that.
JDM_THUG
Dec 1, 2006 07:46 AM
JDM_THUG
Nov 25, 2006 06:20 PM
