CEL code 14 EACV help
Old Jul 31, 2009 | 07:34 PM
sketchen's Avatar
Default CEL code 14 EACV help
okay I just replaced my plugs in my 1990 civic now it wont start im getting code 14 which is EACV where should i go from here should a buy a new ECU or EACV??
Old Jul 31, 2009 | 07:46 PM
are you sure your firing order is correct? did you maybe crack a plug putting them in?
Old Jul 31, 2009 | 07:48 PM
sketchen's Avatar
ya firing order shouldnt have changed i pulled one wire out switched plugs put the same wire back i dont think i cracked one i didnt put em in too tight maybe ill put the old ones in and see if it starts
Old Jul 31, 2009 | 07:51 PM
Unplug the IACV. Do you measure 8-15 Ohms across the two terminals of the sensor?
Old Jul 31, 2009 | 07:55 PM
sketchen's Avatar
i will check when i get my hands on an ohm meter lol. anyone have a pic of where the eacv is on a 1990 civic cx
Old Jul 31, 2009 | 07:58 PM
Old Aug 1, 2009 | 09:16 PM
sketchen's Avatar
pulled the eacv today and gave it a good cleaning it was very dirty now its running better but still idling a little rough. I bought another complete intake manifold today with the throttle body and eacv intact for $5 today so im gonna check the ohms across each eacv and try this other one see if it make a diff.
1stHonda
21
Oct 16, 2010 02:25 PM
BcBaudoux
Mar 20, 2010 07:52 AM
lenwood
Jan 20, 2008 12:20 PM
fglaustin
Jun 22, 2007 12:43 PM
helloheather03
Feb 13, 2007 10:42 PM
