check engine light
Old Mar 14, 2007 | 01:30 AM
89Beater's Avatar
Default check engine light
Today when on my way back home from skool my check engine light came on while i was driving through some hills. it stayed on till i stopped, shut the car off and started it again. y would it do that? also when ever i turn the key on the check engine light(along with all others) then after about 2-4 secs it goes out. is this normal? or is there something wrong?
Old Mar 14, 2007 | 01:42 AM
finalimpact's Avatar
Default RE: check engine light
the check engine light will come on for a few seconds when you turn the key and turn off, its normal. your computer system is obd0..it will turn the cel on when a problem occurs but itll turn off once you shut the car off and then restart until the problem re-occurs. however your ecu will store the code till reset.
Old Mar 14, 2007 | 07:24 AM
FlipHKD720's Avatar
theres also a DIY on here about how to read your CEL (if it ever comes on again for an extended period). This is useful if you want to know whats wrong
https://www.hondacivicforum.com/m_152006/tm.htm
check it out and Good luck!
miguel11691
Nov 15, 2015 08:11 PM
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
Benny Sim
Jul 19, 2005 07:43 PM
