check engine light help
Old Jan 17, 2010 | 03:03 PM
91sihatchback's Avatar
Default check engine light help
My check engine light comes on when i get into higher rpms. I checked the ecu and it came up with a 7 and a 9. What does this mean.
Old Jan 17, 2010 | 03:38 PM
Code 7 is the throttle position sensor, 9 is the #1 cylinder pulse sensor (inside the distributor).
Whenever there is more than one code, reset the ECU (disconnect battery with the key off) and test drive until the CEL comes on again. See which code reoccurs first.
The TPS can be tested with a voltmeter. Turn the key on but don't start. Measure voltage from center wire of the TPS to ground. It should move smoothly from 0.5 volts to 4.5 volts as you pull the throttle from closed to open.
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
fastncrazy1
Jan 4, 2010 05:55 PM
Benny Sim
Jul 19, 2005 07:43 PM
