Check engine light on-no codes
Old Nov 26, 2008 | 09:17 AM
Framez's Avatar
Default Check engine light on-no codes
Newbie here.
I've just bought a 1992 Civic HB SI (Canada version).
It drives like a dream, but I have one peculiar problem that I'm trying to solve.
My "check engine" light has been coming on the past few days; I've had the car for about 3 weeks and never had the light come on before.
I've recently had some preventative maintenance done on the car: timing belt, water pump, ps and alt belts, valve cover gasket, and oil pan gasket.
I brought the car to the shop and they told be that there were no codes showing on the ECU. Is this common? Could the recent work performed on the car be contributing to the light coming on? It seems to coincide with the work that was done.
Some info on the vehicle: ~ 185,000 km; cold air intake added awhile ago but everything else is stock.
Any comments or suggestions would be appreciated.
Old Nov 26, 2008 | 12:45 PM
munkeewrench23's Avatar
what kind of intake you have??
Old Nov 26, 2008 | 01:53 PM
Framez's Avatar
It's actually an SRI. K&N
Like I said, the light has only been coming on the last few days (since the timing belt et al were worked on). The SRI has been on the car since I bought it and I didn't have any lights come on before.
Could there be something that was removed during the last maintenance, that wasn't put back on properly?
Old Nov 26, 2008 | 02:28 PM
try disconnecting the battery and let the car run see if the light comes on again
Old Nov 26, 2008 | 05:28 PM
315 Customs's Avatar
there has to be some kinda of code in the computer for the light to be on. the light wont come on with no code.
Try This and see if you get any codes from the ECU
Old Nov 27, 2008 | 04:30 AM
Framez's Avatar
Thanks for the advice all.
I'll try the suggestions and see what I come up with.
I'll check back when I come up with something.
towelie
Aug 30, 2010 05:08 PM
that_guy5
Mar 16, 2007 07:18 PM
Methu969
Jan 22, 2007 01:13 PM
mobbology
Nov 29, 2006 05:37 PM
emericanidol
Jan 19, 2006 12:47 PM
