check engine will not communicate rough run
Will not communicate with scan tool
SRS light flashing
Rough running
No tach
It all started with bolt on alternator snapping causing bet to slip?
N E help greatly appreciated.
SRS light flashing
Rough running
No tach
Is it an 04 Civic? Has the alternator or its belt now been fixed/replaced and is the alternator now charging to full capacity? Is the battery fully charged? Are the battery terminals and connectors clean and tight?
When you turn the key to ON(II), does the CEL turn ON and then eventually turn OFF? Is fuse 6 or 9 under the hood blown?
civic2004
Nov 10, 2008 04:02 PM
Stumasters
Jan 20, 2008 12:58 PM
samilitant
Jan 8, 2007 10:47 PM
