civic 1997 horn & brakelights problem
Old Feb 10, 2007 | 07:48 AM
hcivics's Avatar
Default civic 1997 horn & brakelights problem
car is 1997 Honda civic 1.4 petrol
The problem is all 3-rear brakelights and the horn are not working at all.
I have checked the fuses, the horn and brakelights operate on the same fuse, but the fuse is ok.
Can anyone offer any help/ advice as to the problem?
[/align]
Old Feb 10, 2007 | 10:13 AM
Red Hot Rider's Avatar
Default RE: civic 1997 horn & brakelights problem
Well, the brake lights are most likely the brake switch up underneath the dash by the brake pedal. Doubt the horn is actually related, probably just a coincidence. If you've checked the fuses, have you checked for voltage at the horn itself?
Old Feb 10, 2007 | 11:59 AM
ej6buddy's Avatar
Answer: the brakelights and the horn are combined on one fuse, check under the dash and replace the fuse with same amp rating.
same thing happened to me, power touched ground and short circuited the system.
Old Feb 10, 2007 | 01:17 PM
Sorry, I'm still learning about this whole Civic thing. heh heh heh
Old Feb 10, 2007 | 11:06 PM
teammo's Avatar
If your car is a hatch, the wires could be broken were they enter the hatch at the top. And you could just have a bad Horn?
Old Feb 10, 2007 | 11:20 PM
ej6buddy's Avatar
ORIGINAL: teammo
come on buddy, the horn just doesn't go out like that along with cut brake lights from the hatch from coincidence, just use common sense, it's a fuse
Old Feb 11, 2007 | 12:32 AM
teammo's Avatar
he said he check the fuses ! And yes it could be a horn and wiring problems I have see that before
islandtuner
Apr 24, 2010 08:37 PM
fq2255
Dec 7, 2007 02:03 PM
kma
Nov 30, 2007 06:28 AM
dapasda
15
Jun 21, 2007 07:10 PM
thebadgator87
Jan 15, 2007 09:53 PM
