civic 2001 limp mode
Old Jun 13, 2013 | 06:15 AM
mc00's Avatar
Default civic 2001 limp mode
hello.
so i replace my tdc sensor yesterday myself so i was getting p1361 and p1362 code
what to check for to see ur car is not in limp mode anymore ? and also how do u test the to see the sensor getting signal with a multimeter?
Old Jun 13, 2013 | 06:37 AM
CEL stays off while driving means it's OK. CEL on while driving is limp mode.
Old Jun 13, 2013 | 06:44 AM
mc00's Avatar
usually does it when im on the highway doing stop and go and on hot days so im actually afraid putting to test. i read u can test to make sure the tdc sensor getting signal by ecu using meter i want make sure the new sensor is working
Old Jun 13, 2013 | 01:44 PM
If you reset the ECU to clear codes, do both codes return?
Old Jun 13, 2013 | 02:56 PM
mc00's Avatar
prior to replacing the sensor I would reset the ECU whenever the car when into the limp mode, and let it sit for few mins than car would run normal like stated before only happen during whenever I did a lot stop and go during heavy traffic and hot days. I replace the sensor I haven't gotten any code yet. What I read the limp mode limit the engine to run no more than 3k rpm and no more than 30mph or less, I was doing 80 to 70 yesterday even 90mph after I replace the sensor and the rpm stay between 3k to 4k or a constant 3k rpm so that's why I'm wondering if im still limp mode or that normal rpm for the honda. when I had my 97 i would do 70mph and higher the rpm would jump to 4k and above
Old Jun 14, 2013 | 11:47 AM
tenacity2986's Avatar
my car went into limp mode not too long ago and just changed the camshaft position sensor... its a little bitch to get to (right side of engine when looking into engine bay) right by the cam belts. I replaced mine and the problem has vanished for months now
mc00
Jun 13, 2013 08:46 AM
Straw Dog
Jan 6, 2013 03:10 PM
snowblind113
May 30, 2011 03:27 PM
shiftbyear
Jan 7, 2010 10:24 AM
civic_turbo
May 2, 2008 07:08 AM
