CIVIC 2002 No start, Relay click on key turn - PLEASE ADVISE
I've got a 2002 Civic that has been doing me bloody well for 2 years now as my first car. It was driving as normal around a week ago only to be started one morning, then nothing... no starter click or burnout or any obvious noises.
I opened up my hood to discover that when I turned my key fully a single click could be heard from the blower motor relay. There is also a secondary click that sounds like a relay coming from the ABS control module that occurs after the first click.
Tried a blower motor relay replacement this morning and am getting the same two clicks
Has anyone had this problem before or got any ideas as to what could be the problem?
Thanks in advance for any responses
Take your battery to an Autozone and have them load test it. It sounds to me as if you need a new battery. If it's on the way out, it will still power things in the vehicle, but will not have the power to turn over the starter. You could also have someone give you a jump to see if the car starts. Good luck.
Duane
Duane
Was you able to find the problem? I am having the same issue now. Thanks
90honda87
Oct 6, 2009 04:36 AM
saiguanas
Sep 11, 2008 01:02 AM
danielintheuk
Sep 17, 2006 01:30 AM
