Civic 96 Lx. Master Window switch
Old Nov 19, 2007 | 04:01 PM
Civic Si 00's Avatar
Default Civic 96 Lx. Master Window switch
Hello my Dad owns a 96 Civic Lx. The back right side window won't go up or down. Yes I have checked the fuses they are Ok. I also removed that door window switch and also it didn't work. More likely the Main Window Switch went bad just the switch that controls the back right window.
How can you test the switch to see if it works. Thanks in Advance
Old Nov 19, 2007 | 05:19 PM
Default RE: Civic 96 Lx. Master Window switch
The picture describes the tests that you need to do.
[IMG]local://upfiles/25538/385F2BCC7AB847BA83FE3FF8230C8747.jpg[/IMG]
Old Nov 19, 2007 | 07:39 PM
ORIGINAL: RonJ
Thanks Ron J. I will check it tomorrow morning.
My Si is acting up is there way to check the Idle Air control valve on my 00 Si. Can you use a multimeter to test it
Old Nov 19, 2007 | 08:32 PM
The pictures here and in the next post show how to troubleshoot both the IACV circuit and IACV function. The latter test does not require a multimeter; you simply apply a jumper wire briefly to two specific terminals of ECM connector B and listen for a clicking sound (see second picture).
[IMG]local://upfiles/25538/9BC2D9674D0A4E608193DAA1EB251435.jpg[/IMG]
Old Nov 19, 2007 | 08:33 PM
last picture...
[IMG]local://upfiles/25538/AB4E350D91224DAD96450617C084395C.jpg[/IMG]
Maximus from the 915
Jul 2, 2010 04:06 PM
cguy7
May 22, 2010 10:02 PM
burnindesirez02
May 19, 2008 11:15 AM
burnindesirez02
Apr 18, 2008 10:43 AM
burnindesirez02
Apr 6, 2008 05:21 PM
