civic dies while driving
Old Jun 17, 2006 | 05:54 PM
penelupe's Avatar
Default civic dies while driving
Hi Everyone,
I have a problem with my daughters 1993 civic ex. The car starts fine then after about 5 mins. It just dies. When you try to restart the car it sounds like it wants to start but doesn't. If you wait about 15 mins it will start up again, then will die again after about 5mins.
Any Idea???
HELP!!!!!!!!!
Old Jun 18, 2006 | 12:14 AM
fglaustin's Avatar
Default RE: civic dies while driving
that sounds like a spark problem. i am not around cars like i was years ago, but back then, the coils would go out when they got hot; but if you leave it cool down, they will work.
when it dies, someone needs to do a spark test; right away.
knowing what has been written here about the EFI main relay - that would be something to check, also.
Old Jun 18, 2006 | 07:42 AM
penelupe's Avatar
I have someone coming by today to look at it. I will have him test that first. I'll keep you posted.
Thanks!!
Old Jun 19, 2006 | 09:34 AM
theredsuit's Avatar
https://www.hondacivicforum.com/m_97869/tm.htm
It's most likely your main relay(man I say this a lot) a common issue with the older civics. I had the exact same problem with my 93. The forum link I put up there has an explanation from me, about why your relay is probably the problem. And I also told the guy how to check if it is. Take 20min, save some money and check it.
kingphilly
Mar 21, 2013 10:23 AM
JantzenRX-8
Jun 17, 2012 01:59 PM
Truespiritfit
Feb 22, 2012 08:05 AM
rickf1985
Feb 22, 2012 07:40 AM
danoco13@aol.com
12
Nov 19, 2011 03:10 PM
