civic running rough when cold
Old May 3, 2012 | 01:16 PM
mycam8u2's Avatar
Default civic running rough when cold
ok it is a 2000 ex. when it is cold it runs rough up to about 2500 rpm then runs kinda good. when it is warm it runs much better throughout the rpm range but still has a lil miss to it. i am wondering if it could be a skipped tooth on the timing belt. no c/e light. i have change the map sensor,o2 sensors, cleaned the valve behind the intake what ever it is called. the spark timing is correct. i am just wondering if it could be anything else? could it be a skipped tooth? i bought the car running this way. thanks for any help and input.
Old May 3, 2012 | 01:43 PM
Make sure the CEL works. It should come on for a bulb test when you turn the key on but don't start.
Misfiring at low rpm and heavy throttle is usually due to weak sparks. The spark plug wires are particularly prone to do this. You can't tell if they are bad by looking, just replace them.
Checking for skipped timing belt is easy enough, take the upper plastic cover off (you will need to lift the valve cover to get it unhooked), rotate crankshaft by hand to TDC, and see if the marks line up. If spark timing comes in correct with the distributor near the center of the adjustment range, timing belt should be OK.
Old May 4, 2012 | 03:50 AM
mycam8u2's Avatar
plug wires look pretty new. they r high perf. its got msd ignition. is there any way to tell if the spark is up to voltage? ill check yhe belt. it really doesnt seem like spark. it runs pretty good when warm.
Old May 5, 2012 | 06:45 AM
mycam8u2's Avatar
any other ideas? the c/e does work
Old May 6, 2012 | 03:10 PM
mycam8u2's Avatar
any other ideas? it only runs rough like this when the engine is cold
Old May 8, 2012 | 12:52 AM
mycam8u2's Avatar
is there anyone who has any other ideas?
Old May 11, 2012 | 05:10 AM
mycam8u2's Avatar
come on guys. i really wanna get this thing running right. just need to know if it could be anything else
Old Jun 11, 2012 | 09:52 AM
mycam8u2's Avatar
i still have not figured this problem out
Rogdenn
Nov 7, 2010 09:49 AM
Stumasters
Jan 20, 2008 12:58 PM
Scott99
Sep 15, 2005 02:32 PM
