Civic Stalling
ok if you're reading this, your civic is stalling.
i have a 1991 honda civic dx and i tried everything to fix the stalling problem. new head gasket, new alternator, new idle air control valve, new main relay and guess what...no difference. brace yourselves peeps because ive found the problem and it is distributor rotor. the part costs about $15 and is fairly simple to replace. upon seeing it you could tell it was the problem. the rotor was worn down and had a crack in it causing it to not fire properly. after replacing it shes been running like a champ. peeps i hope this helps in some way because it caused me nothing but stress and cash.
good luck everyone
.......cause thats how i roll
good luck everyone
thanks for the info man. i just got new headers and my car has been idoling really low and then it'll stall so im taking it to the shop today to get it checked out/fixed. im pretty sure the o2 sensor is messed up but if its not then ill let them know to check out the stuff u mentioned. thanks again!
onday49
Nov 13, 2007 04:27 PM
blahwoop
Jun 25, 2007 10:27 AM
angie828
Oct 4, 2006 10:23 AM
onetrack
Sep 24, 2006 02:15 AM
