Clunking Noise on my Auto Coupe
Old Jul 31, 2007 | 03:23 AM
Chandlergreg's Avatar
Default Clunking Noise on my Auto Coupe
Hi Guys!
I've had my Civic Coupe about a month and I'm getting a knocking sounds when going from reverse to drive, sounds like something expensive, especially as a new gearbox is £2800... anyone got suggestions as to what this might be?
Cheers all.
Old Aug 1, 2007 | 03:31 PM
Impreza WRX's Avatar
Default RE: Clunking Noise on my Auto Coupe
If your Civic is an old one (like 1995 or down)check the "torque stoppers" on the gearbox. You can see them through a hole in the wheel well on the front wheels. It should be a bolt surrounded by rubber that is ATTACHED to the sides. If the rubber is missing, or cracked, this is your problem.
If it is not, then it is possible you have a CV Joint that is about to fail. Does the wheel "knock" when turning hard in a certain direction?
MXandSXracer21
Aug 11, 2012 09:53 AM
cardiy
Jan 25, 2010 09:11 AM
2ManyTickets
Apr 25, 2009 11:24 AM
dsilentninja
Apr 2, 2009 05:50 AM
powderdude
May 11, 2005 03:49 PM
