Clunking noise from rear right wheal area...Help!
Hey I have a 2000 Civic SI. When I go around Left hand Corners there is a clunking noise coming from the rear right wheal area. I've looked at the breaks and suspension components but cant find anything. Can anyone help me?!
I read your post and know that your situation is different. you said left turns, and that it sounds like the rear right. You could possible have the same issue as this guy. Checking it is free, so might-as-well
Good Luck
Good Luck
Thanx for the advice Mario...but my car hasn't been in any accidents. It only seems to happen when the wheel is under load. Also happens while braking so it cant be the breaks. I almost think it might be a bearing as it speeds up and slows down with wheel rotation but anytime I've had a bad bearing it's more of a grinding sort of noise. This is more of a clunking or nocking noise.
When i say the same i don't mean in the sense of being in an and having those same symptoms. i meant hearing the same noises. I've never been in an s, but my CV boot is torn... So replace his posts with yours. What I was trying to do is avoid repost the same thing here as I did there. But do what I told the other guy to do, it wouldn't hurt any. Happy findings!!!
Anyone else with any ideas. Is it possible to do my rear wheel bearings my self? Do I need any spetial tools? And where do these bushings live that ppl are talking about?
droopy128
Jul 20, 2011 09:02 PM
ahackett
Apr 5, 2011 10:43 AM
Blackhawk1969
Mar 22, 2010 10:41 AM
dsilentninja
Apr 2, 2009 05:50 AM
silverbullet01
Nov 11, 2008 08:00 AM
