Clunky suspension, could the ball joint be the culprit?
Old Aug 5, 2011 | 12:31 PM
zazz's Avatar
Default Clunky suspension, could the ball joint be the culprit?
Hey guys,
I have an 01 civic, 80k on it.
Over the last week it developed a clicking/knocking/clunking kind of sound from the front passenger side. The sound got worse pretty fast, gets worse every day. Mostly does it at slow speeds, sometimes clicks once, sometimes several times in a row.
I went under the car, but all i could see was the lca ball joint boot sprung a leak and the grease came out of it. The lca bushings don't look too great either. However i detected no play on the ball joint, tie rods, or bearings. The cv boots are fine.
Would an improperly lubricated ball joint explain this situation? Thanks in advance
Old Aug 5, 2011 | 03:02 PM
boiler1's Avatar
Yes, this can cause noise. Dont mess with a worn balljoint. When they go you pretty much lose control of the car. Replace it ASAP!
Old Aug 6, 2011 | 08:52 AM
zazz's Avatar
The ball joint will certainly get replaced, but i wonder, would it be making sounds if there is no play on it?
Old Aug 6, 2011 | 10:09 AM
With the car lifted off of its wheels, the stress on the suspension is different, so a part that is worn and loose may seem tight because it is being held in a bind.
Old Aug 6, 2011 | 04:29 PM
droopy128's Avatar
I have a popping noise at low speed braking for sometime from driver front and recently changed upper control arm, lower ball joint, lower control arm outer bushing, outer tie rod, brakes and rotors. STILL THE POPPING NOISE.
I may have the same noise as you, let me know what you find. I gave up for now.
theRDRman
Jan 2, 2012 09:17 PM
cesmith
Sep 24, 2007 02:32 PM
SiX
May 2, 2007 12:20 AM
Unc0ntr0l
Apr 17, 2006 03:26 PM
jbarham
Apr 4, 2006 03:05 AM
