Cluster swap
Ok So I did my searching about wanting to install a gauge cluster with a tach on it for the one in mine that lacks the tachometer. I have found that the wiring is already there and is a simple plug and play. What I can't seem to find is what years and models will plug and play. I have a 88 hatchback 4speed with a 1.5l motor. I am not sure of the make of the motor since there seem to be a million different series. Any help is appreciated.
Thanks, I am trying to keep it pretty stock, but like to have a tach for driving. Supposedly if I use the 88 or 89 cluster it should bolt right up and already have the wires right there ready to plug in.
There IS a difference betwen automatics and standards. I actually just went to the wreckers and bought on and plugged it into the harness and it worked perfectly. I did NOT even check the year (other than it was in the 88-91 group). Maybe it was just a stroke of luck? I also like having a tach. Good luck with your car.
1998wagonhatch
Aug 15, 2005 03:36 PM
tom8765432
Aug 9, 2005 10:39 PM
tupi1971
Jul 9, 2005 01:33 PM
