Clutch problem
Old Jul 23, 2006 | 01:09 PM
bw1339's Avatar
Default Clutch problem
Hello,
The clutch in my 91 Civic is acting funny - The clutch will disengage with about 2" of pedal travel, but if the pedal is pushed down further, the clutch will start grabbing again. If I push the pedal all the way down, I can't shift gears.
I have played with the cable adjustment, and while I can move the clutch engagement/disengagement point up and down, it doesn't change its behavior. I now have it set relatively low, to make sure the throwout bearing doesn't contact the pressure plate while driving. What can be causing this?
Thanks,
Mikel
Old Jul 24, 2006 | 01:24 PM
land9's Avatar
Default RE: Clutch problem
adjust the cable so there is about a half inch of free play in the clutch pedal
if it's still at it, looks like you might need a clutch and pressure plate
VXHatchHero
Jun 13, 2010 09:42 AM
NIKE H34D
Jan 5, 2009 01:04 PM
addiction2bass
Apr 13, 2008 05:19 PM
jtvision
Jan 11, 2007 07:58 AM
HARI.
Oct 8, 2006 09:46 PM
