code 2
Old Apr 28, 2005 | 12:28 AM
blackeyes's Avatar
Default code 2
i have a b16a2, cel is throwing a code 2...anybody know what that is?
Old Apr 28, 2005 | 01:16 PM
finalimpact's Avatar
Default RE: code 2
secondary o2 sensor. what kinda car is this engine in? if its in an ef chassis the secondary o2 can be wired into the primary for 1 o2 set up instead of 2.
Old Apr 28, 2005 | 02:27 PM
blackeyes's Avatar
Default RE: code 2
eg coupe, b16a2 engine
Old Apr 28, 2005 | 05:41 PM
Default RE: code 2
are you using the secondary o2 sensor? if not either route it into the primary or use an o2 simulator.
Old Apr 28, 2005 | 07:50 PM
blackeyes's Avatar
Default RE: code 2
where is the secondary o2 sensor located? and when i find it, connect it to the main o2 sensor? and i dont believe im using a secondary because there is only on o2 sensor bong in the header.
Old Apr 28, 2005 | 08:00 PM
AOL.COM's Avatar
Default RE: code 2
a bong is for smokin ---a BUNG is for o2 sensors
Old Apr 28, 2005 | 08:08 PM
blackeyes's Avatar
Default RE: code 2
sorry bout that. dont want people to think im a smoker
and for the people who only read the last post of a thread...where is the secondary o2 sensor located on a b16a2?
Old Apr 28, 2005 | 08:45 PM
AOL.COM's Avatar
Default RE: code 2
should be behind the cat. conv.
Old Apr 28, 2005 | 09:38 PM
sacicons's Avatar
Default RE: code 2
on OBD1?
Old Apr 28, 2005 | 10:24 PM
blackeyes's Avatar
Default RE: code 2
well i have 2 sensors that are not connedcted to anything but i dont know where they go, and there is no place behind the cat for it to go.
and its a odb1
